H90 Tuner-How to set where it mutes
Home › Forums › Products › Stompboxes › H90 Tuner-How to set where it mutes
Viewing 12 reply threads
    • #167585
      rck
        I am activating the tuner on a H90 and it is not muting the sound and allowing my guitar signal to pass through to my amp. How do I program the unit where when I activate the H90 tuner, the sound is muted?
        I am using a simple mono set up, 1/4″ instrument cables going IN 1 and OUT 1.
        What am I missing? Thanks!
      • #167587
            <li style=”text-align: left;”>When the Tuner is up & active, Quick Knob 3.  Thru to Mute.  Click out with the Perform knob/switch, and it’ll remember your preference.
        • #167588
          rck
            Thanks for the help, Brock. I had it set to “Mute” and it is still passing signal. I switched it to “Thru” using the QK 3 and pressed the Perform knob/switch like you advised and it did save the Tuner in that state so I then switched it back to “Mute” using the QK 3 and pressed the Perform knob/switch again it saved it in that state (Mute) but the Tuner is still passing signal.
          • #167591
              Strange, rck.  Mine is staying MUTEd here.  That said, I don’t need to use it that often.  Let me keep an eye on it to see if I can reproduce.
            • #167593
              joecozzi
                Hello rck,
                Are you on the latest firmware OS? Or, have you recently updated the pedal? Try conducting a factory reset by powering up while pressing the first Quick Knob. Be aware this erases your system settings, but I should restore normal functionality to the H90.
              • #167595
                rck
                  Hi Joe,
                  My H90 was running firmware 1.1.4.61, so it is up to date, correct?
                  The factory reset did correct the Tuner “mute” and is operating correctly now and there is no sound when I have the Tuner engaged. Thank you much.
                  • #167598
                      Do you happen to remember if you were using relay bypass when the Tuner would not mute the audio?
                    • #167601
                      rck
                        Yes, I did have the H90 set to Relay Bypass. The same as I did with the H9 and the H9 would mute the signal.
                      • #167654
                          Thanks for clarifying this.
                          When using relay bypass, if the Program is first bypassed and you access the tuner, the audio will always pass thru even if you have selected mute. This will be fixed in a future update, but for now you can just keep the Program active when accessing the tuner if you’d like the audio to be muted while tuning.
                          I’m assuming this is the issue you had because there is nothing else I can think of that would cause the tuner not to mute the audio. If you run into a different scenario where the tuner mute option does not work correctly, please let us know.
                        • #167674
                          rck
                            It appears you are correct and I can consistently get the Tuner to mute when I have a Program in the active state but when a Program is bypassed the Tuner is allowing signal to pass. I can make this work for now at gigs. I appreciate the help and quick support.
                          • #167679
                              Ok, glad to hear this works for you. I can’t provide a timeline for when this will be fixed but I will let you know on this thread when it is.
                          • #168775
                            rck
                              Was this issue fixed in the newest H90 1.3.0 Software update? I don’t see it in the list of issues addressed. Is something you all plan on fixing if not?
                              • #168776
                                joecozzi
                                  Hi rck,
                                  This was not addressed in this update. We will respond here when this has been fixed.
                              • #169765
                                rck
                                  Hi rck, This was not addressed in this update. We will respond here when this has been fixed.
                                  Thank you for that update.
                                  Heads up, I did recently also notice when activating the Tuner that the signal will be allowed to pass through and make sound even if a PROGRAM is activated but the Program Mix is less than 100%. You all may have thought of that, but wanted to make sure you knew of the behavior.
                                  • #169767
                                      Thanks for providing this info. We’ll be sure to test this when we add the tuner/relay bypass fix.
                                  • #171258
                                    rck
                                      Was this fixed with the latest H90 update? I don’t recall seeing it in the notes as so but I just noticed today that the Tuner does mute even when a PROGRAM is in the bypass state….or maybe I’m losing it (my mind). You don’t have to address the latter point I made.
                                      • #171315
                                          Can you be more specific about what you are expecting to happen? I’ve just tested a few scenarios with DSP and Relay Bypass and it seems that the tuner is correctly muting or not muting depending on the setting in the tuner menu. The tuner menu’s mute/thru setting will be applied regardless of the Program bypass/active setting.
                                      • #171333
                                        rck
                                          Thanks for clarifying this. When using relay bypass, if the Program is first bypassed and you access the tuner, the audio will always pass thru even if you have selected mute. This will be fixed in a future update, but for now you can just keep the Program active when accessing the tuner if you’d like the audio to be muted while tuning. I’m assuming this is the issue you had because there is nothing else I can think of that would cause the tuner not to mute the audio. If you run into a different scenario where the tuner mute option does not work correctly, please let us know.
                                          I am referring to my original post and specifically the behavior mentioned in the latter of the above quotes. I am expecting when the H90 is in Relay Mode that the Tuner passes signal through when a PROGRAM is not activated and in Bypass mode as it has done since I’ve had the unit 11/22 and why I initiated this thread. It no longer does this and does actually MUTE the signal when a PROGRAM is not activated and in Bypass mode and also in Relay mode. I have the most current H90 and H90 Control software updates.
                                          Was this fixed in the most recent update?
                                          • #171335
                                              Yes, this issue has been fixed in the latest update. From my testing, I am no longer experiencing the issue, and from what you describe it seems like you aren’t experiencing the issue either.
                                              Sorry for the confusion. There were many fixes and new features for this update and it looks like we missed this in the release notes.
                                          • #171337
                                            rck
                                              Dude, all good, all good. Thanks for the clarification and to you all for ‘fixing’ this in addition to the Envelope feature of TriceraChorus.
                                            • #195693
                                              amc8
                                                Hey folks sorry to hijack this old thread – I swear I used to be able to activate the tuner and have effect tails trail over, ie: muting input only when tuner is activated. Wondering if that is an option as currently I seem to only be able to pass all audio, including input while tuning, or entirely mute everything and cut abruptly to silence rather than having time based fx trail over
                                                • #195698
                                                    The Tuner’s mute/thru function has not change.
                                                    If set to Mute, the signal will be muted.
                                                    If set to Thru, you will hear your instrument being processed by the H90 as you tune.
                                                • #195708
                                                  amc8
                                                    Thanks for the response. Yep I got that but has the tuner always been placed after the fx slots? Ideally it would be before fx like in a standard pedal chain so your delays and reverbs could trail off while you tune rather than being cut. Kind of whack having to wait for everything to fade away before tuning.
                                                    • #195723
                                                        Yes, when set to THRU, the tuner will always be post FX. This behavior has not changed.
                                                        If you want your tails to ring out, you can first bypass the Program, and then enter the tuner.
