H90 Volume Bump When Bypassed
Home Forums Products Stompboxes H90 Volume Bump When Bypassed
Viewing 4 reply threads
    • #171368
      nateboykin
      So- even when my H90 has the presets bypassed- when I put the pedal into the signal chain (via my Crocodile Tail Loop) my signal gets a significant volume boost. This still happens when there is nothing else in the signal chain except the H90. Is there a way to adjust this globally so I don’t have to adjust every preset individually?
    • #171387
      joecozzi
      This does not sound like normal operation. Try putting two THRU utility algorithms on a Program. When you bypass the H90, there should not be any apparent drop or increase in volume. If you do experience that, I recommend conducting a factory reset. Before you do, back up your Programs to a list and record any system settings.
    • #172001
      nateboykin
      K- factory reset did not resolve the issue. That is after setting both programs to the default Thru setting. Is there a general global input / output balance I should be adjusting?
      • #172071
        The only general input/output gain settings are instrument/line level operation. You can probably leave these at the default instrument level for your setup.
        The Program and each Preset all have input/output gain levels, can you please make sure that these are all at 0 db? It can be easy to not realize that a Program gain level is boosted or cut.
        Press the Parameters button a few times to see the different parameters for the Program and each Preset. Use the Select knob to scroll through the parameters until you’ve made sure that all of the input/output gains are at 0 db.
        You should also make sure the mix of everything is set to 100%. A Mix level of 50% can have a perceived volume increase because it is the full volume of both the wet and dry signals.
        If you try all of this and still find that there is a perceived volume increase, please try using just the H90 and an amp without the switcher and let me know if you experience the same thing.
    • #183250
      markninel
      Hi bro!
      I have seme problem too.
      When I seting up and down output gian or mix on a  program, if I bypass h90 The volume changes accordingly,This doesn’t happen on my h9.
      So how to solve this problem.?
      Thank you!
      • #183257
        The input/output gains are only applied when the Program is active. If you bypass the Program, you will not have any change in input/output gain.
    • #183282
      markninel
      I try change my bypass mode from dsp to AB.
      The problem is solved.
