H90 with 2 synths on different outputs
Home Forums Products Stompboxes H90 with 2 synths on different outputs
    • #182439
      donatoditrapani
      I’m struggling trying to figure out the right configuration (if it exists) to connect two synths to the H90.
      What I would like to do is connecting:
      – a stereo synth to In 1-2 —> Programs A and B —> Out 1-2
      – a mono synth to In 3 —> Programs A and B —> Out 3
      I did understand I should use Insert Mode, but I’m not sure about the routing (i.e. how can I make sure In 3 goes out on Out 3? etc)
    • #182441
      joecozzi
      It’s not possible to use both presets for two distinct signal flows as you’ve described. The closest you can get is using Dual mode and loading one preset on each path. Path 1 goes In 1-2 to Out 1-2. Path 2 goes In 3 to Out 3. This video explains Dual mode: https://youtu.be/0G_WtfUatSc?t=195&si=m_GwLjL2aLrPxsBQ
      What you can do is connect a synth to 1-2 and another to In 3 and have them both go through both presets and get mixed to Out 1-2. Insert mode is better for making the H90 function like a mixer as described in this video: https://youtu.be/0G_WtfUatSc?t=1190&si=Sswgbo_1xX0a3cVz
