H90 with HX Stomp
Home Forums Products Stompboxes H90 with HX Stomp
    • #175358
      promero85
        Hi, do you know the best way to connect my H90 with the HX Stomp? I would like to be able to:
        1) use it as a audio interface
        2) use the phono output to play quiet at home
        3) put pitch shifting / drive effects of the H90 before the amp modeler of the HX stomp
        4) put time based effects of the H90 after the amp modeler of the HX stomp
        <span style=”font-size: inherit;”>Thanks in advance. </span>
      • #175359
        joecozzi
          Hi promero85,
          Since you want to use the HX Stomp as your interface and headphone amp, it’s best to make sure its output is the last thing in the chain. My recommendation is to run your H90 in Dual routing mode. Place Preset A on Path 1 and Preset B on Path 2.
          1. Connect your Guitar to the H90 on In 1.
          2. Take Outs 1&2 from H90 to Inputs 1&2 on the HX Stomp. (For mono, just use I/O 1). This will allow you to use Path 1 on H90 for your drive and pitch effects.
          3. On the HX, create an FX Loop block and place it after your amp model.
          4. Connect from HX’s FX Loop Send to H90’s Ins 3&4 (or just 3 if you only need mono).
          5. From H90s Outs 3&4 connect to HX’s Returns 3&4. For mono, just use I/O 3. This places H90’s Path 2 after the amp for time-based effects.
          Now, you’ll be able to connect the HX’s outputs to your FFR monitoring system and/or use headphones.
        • #175362
          promero85
            <p style=”text-align: left;”>Thanks for your prompt reply Joe! I will give it a try and let you know how it goes.</p>
