Home › Forums › Products › Stompboxes › H90 with mesa triaxis
- This topic has 4 replies, 2 voices, and was last updated 10 months, 3 weeks ago by
joecozzi
Eventide Staff.
March 25, 2024 at 5:18 am #180025
arnaudvigneron
ParticipantHello I’m french. I have a mesa boogie triaxis and I connect the two outputs to the two inputs of the H90 pedal and I have it configured as dual. I use the first input for the effects before the triaxis and the second inputs for after the triaxis. but I only have one output after the H90 pedal which works. I don’t understand. Can you help me please? I think it comes from a parameter of the H90 because with the same connection it worked with a fractal. THANKS
March 25, 2024 at 10:20 am #180054
Are you using a factory Program or a custom program? Just for testing, I would use an INIT Program found on User 2 list and make sure Preset A is on Path 1 and Preset B is on Path 2. This is a blank Program designed to just let sound through. Can you hear a clean signal pass through? If not, the best thing to do is simplify your signal flow to narrow down the cause of the problem. I would bypass the GCX switcher, the Cry Baby, and the decimator. Plug the guitar straight into the H90 to see if you get signal going through the preamp and back into the H90; look at the input LED meters for signal on In1, In 3, and In 4. You should be seeing green lights. Once you determine everything is working properly with your preamp and amps, then you can begin to add other things between the guitar and the H90. Then add the decimator. It’s not uncommon for the problem to bad cables or improper connections.
March 25, 2024 at 1:59 pm #180113
arnaudvigneron
ParticipantGood morning. Thank you for your answer I will try this weekend as you advise me. thank you but I doubt that it comes from cables or others because I made this configuration with different multi effects. It works on certain presets that I use in clean but I can’t find why…
April 13, 2024 at 7:37 am #180971
arnaudvigneron
ParticipantGood morning. It was very stupid to find but I hadn’t seen it! on the triaxis the stereo volume button is double and there was one which was at zero….there is no longer any mark on the button so I never saw anything😆 really stupid 😆
April 13, 2024 at 11:21 am #180982
Glad you solved the issue. Thank you for reporting back.
