H90 with OX box
Home › Forums › Products › Stompboxes › H90 with OX box
Viewing 5 reply threads
    • #184039
      squidz66
        Hi all, I’m wondering if someone may help me?
        I’m wanting to use my compressor and drive before my H90 (so I can use drives etc.), then into my amp, then into my OX box, back into H90, out to s<span style=”font-size: inherit;”>tereo monitors.</span>
        I feel like I’m missing something here. I want to come out in stereo.
        I’m currently going in compressor pedal into in1
        Out1 into amp
        Ox out into input 3+4
        Out 3 and 4 into monitors.
        I’m so sorry for such a basic question..
        But I can’t figure this out.
        Can anyone help me?
        I can’t seem to get this to work
        Thanks
      • #184040
        squidz66
          Do I put the Ox as an insert?
        • #184042
          squidz66
            Is there a way to go into h90, into my amp, out of amp?
          • #184043
            squidz66
              I’m thinking the only way I can do it is, pedals in front. Stereo out…so I can’t have anything before
            • #184058
                The Ox Box should not be used as an insert as it needs to connect directly to your amp.
                I would suggest using Dual Mode on the H90 and trying this:
                Guitar > Compressor / Drive pedals > H90 Input 1
                H90 Output 1 > Guitar amp input (amp connected to Ox Box)
                Ox Box Outputs 1-2 > H90 Inputs 3-4
                H90 Output 3-4 > Stereo monitors
                This setup will allow you to have different effects before/after the preamp stage. Press the routing button to choose which preset is on which path: https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/edit-modes/routing.html#dual-routing
                Let me know if you have any questions.
              • #184069
                squidz66
                  Thank you so much for the reply. I think I didn’t understand the insert/dual routing scenario. I’ll give thatxa crack. Thanks.
