H9000 analog inputs 1 and 2
Home Forums Products Rackmount H9000 analog inputs 1 and 2
    • #115240
      cyborgssc
      The H9000 maual states that the rear panel XLR analog connectors are a duplicate “mult” of channels 1 and 2 on the DSUB connectors. I understand how this works for the analog outputs. How does this work for the inputs? If signal is present both on the XLR and the DSUB inputs 1 and 2, are they summed? If so, actively or passively?
    • #151513
      jbamberg
      cyborgssc wrote:
      The H9000 maual states that the rear panel XLR analog connectors are a duplicate "mult" of channels 1 and 2 on the DSUB connectors. I understand how this works for the analog outputs. How does this work for the inputs? If signal is present both on the XLR and the DSUB inputs 1 and 2, are they summed? If so, actively or passively?
      The XLRs and DSUB 1/2 are different connections to the same inputs.  They aren't really intended to be used simultaneously.
      • #151514
        cyborgssc
        jbamberg wrote:
        The XLRs and DSUB 1/2 are different connections to the same inputs.  They aren’t really intended to be used simultaneously.
        Understood, thanks.
