h9000 (and maybe other) session management
Home Forums Products Rackmount h9000 (and maybe other) session management
Viewing 6 reply threads
    • #115943
      joeydego
        How do you guys typically keep track of your Eventide session assignments? Do you assign a session per song and leave that in your sessions preset list? It has recently occurred to me to start saving an Eventide session file IN the DAW session folder for recall along with the song. Question: if I have an Emote VST loaded in my DAW session, does it also have Eventide session information and upon launching the DAW session, will it switch sessions on my H9000? THIS would probably be the best most pain free way.
      • #155007
        John Baylies
          I assign one session per band/project. I haven't had to switch whole sessions between songs, just FX chains. I give the chain the same name as the song, save it to the H9000, and drag it in when I need it.
          The plug-in currently gives DAWs control of FX chain bypass, mute, mix, in gain, out gain, and functions, but it does not support swapping sessions, chains, or algorithms.
          Once Emote supports scenes then DAWs will be able to swap sessions through Emote.
        • #155008
          joeydego
            Thanks for getting back to me. Hopefully Eventide will consider adding this feature in the future.
          • #155011
            John Baylies
              Indeed: https://www.eventideaudio.com/comment/38852#comment-38852
              edit: do you have the H9000 or the H9000R? The H9000 currently supports scenes, but the H9000R does not.
            • #155012
              joeydego
                I do have a 9000
              • #155013
                John Baylies
                  I have the R, but you can send MIDI from your DAW to the H9000 to load the scene you want for the project. I can understand how it'd be nice if that functionality were baked into the plug-in, though.
                • #155014
                  joeydego
                    Although the scene function does seem useful, it appears it has no control over algos or routing, which for me changes song to song, especially since I’m still diving in and discovering new sounds and uses. I think in my case until firmware changes, I’m best served keeping each song its own session and saving those files in my DAW session folder.
