H9000 + Boss FS-6 footswitch not happening
Home Forums Products Rackmount H9000 + Boss FS-6 footswitch not happening
    • #169826
      bryantalbot
        Followed all directions to the letter, all settings on the footswitch (a 2-switch) as they should be, fresh footswitch battery, and somehow the 9K does not like the FS6 at all.
        At first, the 9K did recognize the switch, green lights 1 & 2 lit, but only FS2 would control a parameter, FS1 would not.
        After undo-redoing the necessary steps to register and calibrate the footswitch, both the hardware and Emote slowed down almost to the point of crashing. I restarted everything, tried the whole process a couple more times, but then the footswitch wouldn’t register at all and everything bogged down again.
        Anyone know of compatibility issues? Is there a different DUAL footswitch that works?
        TIA
      • #169880
        bryantalbot
          EDIT – never mind – will buy the pedal from the shop
