April 30, 2020 at 5:17 pm #115893joeydegoParticipant
Is screen burn in a concern?? Just wondering.
April 30, 2020 at 5:56 pm #154766joeydego wrote:Is screen burn in a concern?? Just wondering.
I asked a colleague about this and he said: "TFT and LCD displays don't have burn-in issues, but they can develop image persistence issues that go away after ~48 hours unpowered"
The backlight might also have a limited lifespan, but using the screen dim feature (which can be enabled in the Preferences page in SETUP mode) should extend it.
May 1, 2020 at 2:06 pm #154783macgeeParticipant
Are you using the screen in H9k constantly?
I use mine occasionally but mainly using emote now.
So have mine setup to reasonable brightness and then it dims to zero after a couple minutes or so.I had the same concern as you so asked your same question and now use as above to make the screen last longer
Yes, the range is from 0 to 10. However, the difference between 0 (off) and 1 (on) is faaar too great for fine adjustments. 1 should be much darker.
May 1, 2020 at 2:27 pm #154784joeydegoParticipantmacgee wrote:Are you using the screen in H9k constantly?
The screen can be set to turn off?
May 1, 2020 at 2:31 pm #154785macgeeParticipantjoeydego wrote:The screen can be set to turn off?
well can be set to dim and using the brightness and dim vals have it going dark and i actually can’t see anything on the screen so i think it’s off?
