H9000 Feature Request: Larger Note Display
Home Forums Products Rackmount H9000 Feature Request: Larger Note Display
    • #171426
      gustebeast
        Would it be possible to increase the size of the current note display when using the chromatic tuner algorithm? I use the H9000 in a live setting and it would be helpful when showing other musicians what note I am playing.
      • #171539
          Thanks for your request. Can you be more specific with how large you’d like the note display to be? Something like the entire display being dedicated to the tuner? Or just slightly bigger than it already is? This might be something we can add in a future update.
        • #171540
          gustebeast
            I would suggest to make the note as large as possible while still fitting within the box. Here’s an image showing what I mean:
            0525231205_HDR
            The error cnts could be a bit bigger as well. Maybe it could use the same top/bottom layout that the note uses. “Error” on top and the cnts below with a font size increase (doesn’t need to be as big as the note)
