H9000 : How to side-chain a compressor to create a ducker?
Home › Forums › Products › Rackmount › H9000 : How to side-chain a compressor to create a ducker?
Viewing 4 reply threads
    • #115343
      zazula
        I’m trying to duck a signal in an FX Chain and cannot find a compressor that has a side-chain.  Is there one?
        My flow is IN -> Delay -> Blackhole -> Flanger -> Compressor
        I want to side-chain the compressor using the IN signal.
      • #152033
        macgee
          I looked in the H8000 presets manual and actually couldn’t find any comps that mentioned sidechain other than gates. There’s ducking but not on comps
          Is this right?
          Is your FX chain 100% wet and on the comp you are looking for a 3/4 in 2 out?
          2 for stereo input and 3/4 for the side chain signal?
          Stereo out for the ducked “Delay -> Blackhole -> Flanger”
          I couldn’t see this capability but maybe someone else knows more – should be achievable with a bit of VSIG
        • #152038
          macgee
            You can try this if you want – I needed to add a comp to an algo I’m working on so just built Comp on it’s own with sidechain
            The detector config is what you use to choose from different Input sources, stereo, mono or summed
            Pop on USB Key and can import on H9000
            https://www.dropbox.com/s/68cjt2x0cfs6clc/Comp%2BSideChain%201_4132979866.9ka-CompiledALGO.zip?dl=0
            Let me know if any issues
            • #152039
              zazula
                Are you using Vsig for this?  Does Vsig work for the H9000?  I was using VsigX on MacOS but may need to format a computer with windows if Vsig is working for the H9k.
              • #152045
                zazula
                  I just tried loading this and it doesn’t show up on the H9000.  Formatted USB stick FAT and put the k9a file on it.  I don’t see any entries when I say “Load Algorithms”.  It does say that it “read EFI” when I put the USB stick in.  I’m on firmware 1.1.5.
              • #152044
                macgee
                  Yea, in Vsig adapted for H9000 – I’ve been running it in Windows VM, it’s fairly easy to setup
                • #152046
                  macgee
                    Weird, I’m not sure why that would happen.
                    In that case here’s the Vsig
                    https://www.dropbox.com/s/on9gcaw15dzilmn/Comp%2BSideChain.sig2?dl=0
