- This topic has 7 replies, 5 voices, and was last updated 2 years, 1 month ago by
parkerfly81.
December 25, 2022 at 2:15 pm #167946
spandavision
ParticipantIs there any road case which would allow for safe checked-baggage air travel for an H9000?
December 25, 2022 at 2:26 pm #167948
The times I have traveled with my H9000 and taken it on a plane, I’ve used this case without issue: https://www.skbcases.com/products/4-u-i-series-injection-molded-wireless-mic-fly-rack
In order to keep it under 50 lbs, I’ve had to not include any cables, power conditioners, and not much else in the rack. Make sure you weigh it and it abides by your airlines weight guidelines. You have to check it in.
December 25, 2022 at 2:30 pm #167949
wvought
ParticipantWhichever case you use, expect LONG DELAYS.
December 27, 2022 at 7:00 pm #168002
spandavision
Participantwhat do you mean by long delays?
December 31, 2022 at 9:50 pm #168081
ddv
ParticipantLOL, thanks for the laugh!
December 27, 2022 at 7:19 pm #168005
wvought
ParticipantSorry, it was a joke.
H9000, long delays…think about it.
December 28, 2022 at 9:21 pm #168034
spandavision
ParticipantThe times I have traveled with my H9000 and taken it on a plane, I’ve used this case without issue: https://www.skbcases.com/products/4-u-i-series-injection-molded-wireless-mic-fly-rack In order to keep it under 50 lbs, I’ve had to not include any cables, power conditioners, and not much else in the rack. Make sure you weigh it and it abides by your airlines weight guidelines. You have to check it in.
i’m happy to hear the H9000 can survive checked baggage handling. Thanks for the SKB case recommendation. I will try this.
February 10, 2023 at 12:26 pm #169030
parkerfly81
Participanti’ve flown a bit with it in a pelican 1615 using a 2 space rack from CP cases.
(https://cpcases.com/erack/19-inch-rackmount-chassis)
super lightweight at 5lbs, but incredibly solid.
it’s underweight (even with other things in the pelican (cables, DI, midi controller..) and not considered oversize.
hope that helps.
r
