- This topic has 6 replies, 4 voices, and was last updated 7 months, 2 weeks ago by gustebeast.
April 4, 2024 at 1:22 pm #180496gustebeastParticipant
Has Eventide considered adding a new 8 channel input and output option called “Loopback” which just feeds the output back into the input? This is already possible if you select ADAT as your digital audio mode and then plug the optical OUT into the IN with an optical cable. The problem with that method is that it prevents you from using digital in/out for other uses.
This would be a pretty powerful addition:
Chain multiple FX Chains together
Have FX 1 send to loopback 1, have FX 2 receive from loopback 1
Have multiple FX Chains output to the same output
FX 1 sends to loopback 1, FX 2 sends to loopback 2, FX 3 takes loopback 1 and 2 and sends to USB 1
April 5, 2024 at 10:09 am #180603
Yes, we have considered methods for linking FX Chains together. I can’t comment on if/when this will make it into an update, but we have been discussing this recently and are looking into the possibility.
April 5, 2024 at 2:17 pm #180661gustebeastParticipant
For context, my reason to do it isn’t to chain more than 4 effects in a row, it’s to use an FX Chain as a mixing stage where I can take multiple outputs from other FX Chains and mix them down to a single stereo output for monitoring. An output becomes locked once it’s used by an FX chain so this isn’t currently possible.
Linking FX chains seems like a way to solve this organizational issue (currently can’t put different instruments in different FX chains and have them go to the same monitoring output) as well as give other users the option to “go crazy” with chaining more than 4 effects in a row.
Glad to hear y’all are looking into it, it’s exciting that such a great unit still has potential to get better.
May 15, 2024 at 2:31 pm #182718gustebeastParticipant
I ended up figuring out an alternative solution here. I am using the ADAT 8 channel output, sending that to a Midiman Sam which mixes it down to a stereo S/PDIF for monitoring.
So clean now 🙂
June 3, 2024 at 10:02 am #183027purpose.annelyseBlocked
Thanks for you
June 3, 2024 at 4:50 pm #183035PuppeteerParticipant
I have a mix algorithm available here to allow 4 stereo inputs to be mixed to 1. A pro version is also available with additional features
June 3, 2024 at 4:59 pm #183036gustebeastParticipant
That wouldn’t help because the signals that need to be mixed are in different FX chains. Ideally Eventide would allow you to use the same output in multiple FX chains and mix them together automatically, but sparing that I can use an external mixer to get what I need.
