Home › Forums › Products › Vsig and Preset Development › H9000 MIDI Test Algorithm Issue
- This topic has 7 replies, 4 voices, and was last updated 2 years, 2 months ago by
cunt.
July 10, 2024 at 10:02 pm #183689
I’m trying to make an algorithm which I can use to change presets on a connected PC via named buttons.
Here’s the algorithm:
https://drive.google.com/file/d/19HmtOVsgNK_jQhkKl6p1_D-SjIcq5FE-/view
I’ve got my H9K connected to my mac via USB B, but I’m not seeing any MIDI messages appear in MidiView (app for monitoring MIDI). Not sure if I did something wrong with the algorithm or my MIDI output isn’t working. I tried the Midi Remote Cntrller algorithm and similarly don’t get any MIDI message when clicking the trigger button.
July 11, 2024 at 9:47 pm #183701
July 11, 2024 at 10:38 pm #183703
Thanks for the test algorithm. I tried it both with USB B and a MIDI -> USB adapter (I’ve confirmed the adapter works with a spare midi keyboard). Either way, nothing coming out of the H9K.
Any chance you can try the algorithm on your own H9K? I’m suspicious that the midicout algorithm has a bug.
July 11, 2024 at 11:10 pm #183704
I’ll have a look when I get a chance.
July 12, 2024 at 10:26 am #183707
We’ll have to look into this further, but this is most likely due to a limitation of the H9000 not currently being setup to output MIDI data.
It is only guaranteed/tested to output MIDI when using MIDI feedback: https://cdn.eventideaudio.com/manuals/h9000/2.0/content/setup/h9000setup.html#midi
Outputting clock, CC, PC messages, etc are not currently supported.
July 12, 2024 at 1:31 pm #183713
Are Midi Remote Cntrller and midicout relics of an older device that did support MIDI out?
Is this something that could be fixed in a future firmware update or is it a limitation baked into the hardware? For now I should be able to use a mobile app to send MIDI messages but definitely would be nice to be able to do it via the H9K.
July 12, 2024 at 2:18 pm #183716
Yes, the MIDI remote controller is an algorithm designed for the H8000 (or maybe another older rack mount unit).
Yes, this could be possible on the H9000 in a future firmware update, but I can’t say if or when we will add this feature.
Sorry for the confusion.
July 12, 2024 at 8:59 pm #183717
is there a good saturation?
