H9000 – some presets not loading correctly
Home Forums Products Rackmount H9000 – some presets not loading correctly
    • #165112
      bsfreq
        Just noticed a problem with some saved presets not loading correcly.
        For example 9401 – Hall, if I load the factory preset no. 11, “HALL”, the low-level (and high level) in that preset is loaded and shown as -100. However it does not affect low levels unless I turn the knob a little bit and then turn it back to -100!
        Is this a known issue? I tried moving the knobs and saving the preset again, but the same problem remains, so it’s not just a corrupt preset file..
        I really need my presets to load correctly, so I hope this is not a widespread issue.
      • #165117
          Thanks for reporting this issue. I am able to reproduce this with some Hall presets but I have not come across this issue with other algorithms. I would suggest using another hall reverb algorithm until we’ve had a chance to look into this and fix the issue. Sorry for the inconvenience.
