H9000 Thru preset question
Home Forums Products Rackmount H9000 Thru preset question
Viewing 3 reply threads
    • #169575
      OsedEsahc
        In the manual it says the “thru” preset is an “electronic” connection between the input and output. Does that mean there’s no A/D D/A conversion happening? Almost like a true bypass?
      • #169576
        joeydego
          If your IO is digital, then the only conversion is coming back out of your interface to however you’re monitoring. If your IO is analog, then that portion of the signal chain will obviously be converted.
        • #169579
            Yes, joeydego is correct here.
            Keep in mind that any algorithm in the FX Chain will introduce a small amount of latency. Any time I use a Thru algorithm it’s usually to troubleshoot my routing and make sure audio is passing.
            If you’d like to route your input to your outputs with no effects processing, you can use Direct I/O routing – https://cdn.eventideaudio.com/manuals/h9000/2.0/content/emote/views/directIO_view.html
            Direct I/O routing allows you to use your H9000 as a digital patchbay while still have access to all 4 FX Chains.
          • #169583
            OsedEsahc
              Excellent! Thanks so much for the help!
