H9000 + WHAT for guitar recording?
Home Forums Products Rackmount H9000 + WHAT for guitar recording?
Viewing 4 reply threads
    • #115247
      zengomi
        Hello!
        One aspect of the H9000 that I’d like some clarification on is its use in recording an electric guitar. I have a nice preamp (Atlas Pro Audio Juggernaut Twin) to start the chain. From there, I’m wondering to what extent the H9000 can take the guitar sound to a recording. Digitally conecting with my iMac isn’t a perogative. I’m totally OK with analog.
        Does anyone here use an H9000 to record an electric guitar?
        Cheers!
      • #151560
        floresp640
          zengomi wrote:
          Hello!
          One aspect of the H9000 that I'd like some clarification on is its use in recording an electric guitar. I have a nice preamp (Atlas Pro Audio Juggernaut Twin) to start the chain. From there, I'm wondering to what extent the H9000 can take the guitar sound to a recording. Digitally conecting with my iMac isn't a perogative. I'm totally OK with analog.
          Cheers!
          There are many ways to be able to achieve this. I am not familiar with your setup but the H9000 will function just like any other Hardware box. You will still use it in your session as a hardware insert into your track. If you are avoiding using the H9000 in a 'Digital Domain', you can take advantage of the 8 channels of analog I/O. The H9000 is very capable of taking your guitar recording and turning it into something completely different using the available algorithms.
          Although, there is no way to directly plug in your guitar to the H9000, you can still use it as an insert onto any track using your DAW.
          I hope this answers your question! Please let me know if there is anything else I can do to help.
          • #151561
            zengomi
              floresp640 wrote:
              zengomi wrote:
              Hello!
              Cheers!
              There are many ways to be able to achieve this. I am not familiar with your setup but the H9000 will function just like any other Hardware box. You will still use it in your session as a hardware insert into your track. If you are avoiding using the H9000 in a ‘Digital Domain’, you can take advantage of the 8 channels of analog I/O. The H9000 is very capable of taking your guitar recording and turning it into something completely different using the available algorithms.
              Hello!
              Thank you for replying and offering to help further.
              Most of time, I would like to play guitar without using a DAW. Does the following chain make sense?
              Guitar > preamp > H9000 analog input > H9000 analog output > mixer > audio interface > computer
              How would you personally bring your guitar’s sound into the H9000 when it is not used as a DAW insert?
              Thanks again for your help!
            • #151562
              floresp640
                zengomi wrote:
                floresp640 wrote:
                zengomi wrote:
                Hello!
                Cheers!
                Hello!
                How would you personally bring your guitar's sound into the H9000 when it is not used as a DAW insert?
                That would work! This would be the simplest way to set it up but you would have to keep an eye on your input gain which you can control within the H9000 (analog input gains).
                Im not very familiar with your setup but it sounds like you might not even need the Audio interface and the Computer if you will not be using the DAW.
              • #151564
                zengomi
                  floresp640 wrote:
                  zengomi wrote:
                  floresp640 wrote:
                  zengomi wrote:
                  Hello!
                  Cheers!
                  Hello!
                  Thanks again! That answers my question precisely.
                  For playing and preparing, no DAW necessary. Eventually, though, I’d use Logic, either to record or to import a recording.
              • #151563
                floresp640
                  Although I recommend using a computer anyway for using Emote
                  • #151565
                    zengomi
                      Actually, I would use a computer for Emote because I’ll probably buy an H9000R.
                  • #154198
                    joeydego
                      Did you ever get this sorted?
                    • #154199
                      zengomi
                        Went in a completely different direction. Bought two UAD Apollo x8p and tons of plugins.
                      • #154200
                        joeydego
                          wow you have a ton of I/O there! I bought an x8 and an H9000, utilizing all my I/O with the Eventide, 8 ADAT and 8 analog channels.
