- This topic has 3 replies, 1 voice, and was last updated 1 year, 8 months ago by
gustebeast.
July 29, 2020 at 9:06 pm #116017
Hello – is it possible to have more than one Dante card in a single H9000? I already have one Dante card and a MADI card, but the 3rd slot is empty.
This should work fine. The cards will appear as two separate 32 channel Dante devices on your network. As you probably know, the Dante ports in the back are in pairs and each pair is connected to an internal network switch, so you can daisy chain the two cards (you don't need to run two ethernet cables back to your main switch). How is your studio's clocking set up? The most common configuration in a pure Dante setup would be to let Dante take care of the clocking and set the H9000 clock source to follow one of the two cards.
July 8, 2024 at 5:39 pm #183644
Did you end up getting the second card? I’m considering getting two cards but I want to double check that you can connect them with an ethernet cable, set up a connection in Dante Controller, then disconnect them from the rest of the network and still have them send audio back and forth via the pre-configured connection.
July 31, 2020 at 11:30 am #155439jbamberg wrote:
This should work fine. The cards will appear as two separate 32 channel Dante devices on your network. As you probably know, the Dante ports in the back are in pairs and each pair is connected to an internal network switch, so you can daisy chain the two cards (you don’t need to run two ethernet cables back to your main switch). How is your studio’s clocking set up? The most common configuration in a pure Dante setup would be to let Dante take care of the clocking and set the H9000 clock source to follow one of the two cards.
Great, thanks. My H9000 is already clocked to the Dante network – everything in my studio is Dante.
