H9000R live usage
Home Forums Products Rackmount H9000R live usage
    • #115888
      Harpo
        this is my first post, so I first like to say how great the H9000 sounds!
        Also the handling is good if you master some entry level problems…
        I try to find a way to use it for live performance. As I learned in the forum the scenes will come in the next emote version.
        But in between I found out the H9000R recovers the last session. Also assigned midi controllers are recovered – very good!
        My question is: where get the data of the current session saved?
        Is it in internal battery buffered RAM? Or is it on the USB stick?
        Thank you very much
        Sebastian
      • #154746
        floresp640
          Thank you very much
          Sebastian
          Hi Sebastian,
          The Session data is stored within the H9000 internal storgare to recover the last session. However, you can save your session to external thumb drives or to your computer so that you have it as a backup or to move your sessions between different units.
          Hope this helps!
          Best,
          Pat
        • #154767
          J20056
            Is there an update on when the Scenes will be available for the 9000R? I literally cannot use my MIDI pedalboard to switch presets (via Scenes) at all and have to use Emote via computer to do that. I recall being a high priority, but that was 4 months ago. Is there a realistic ETA, even if beta and totally unstable?
          • #154804
            jfirlik
              We've been working to push out some critical fixes and hardware support in a new 1.2 beta — that should be released soon and Scenes support in Emote is still highest on our list to come after that.  Can't promise an exact ETA but it shouldn't be much longer before we have something that users can try.
