Home › Forums › Products › Stompboxes › H910 chromatic scale display
February 12, 2014 at 2:22 pm #111387KubicixfactorMember
On the H910 setting I'm trying to just detune by a semitone. However the pitch display doesn't display a chromatic scale. I've tried using the scale/speed knob to select "chromatic" but the display still shows a decimal scale. Any advice please on how to set this up for a detuned semitone down?
February 12, 2014 at 2:30 pm #125399
The H910 alg is true to the primitive display and control of the original hardware. A semitone is 6% up or down from unity. So, 1.06 or 0.94.
February 12, 2014 at 2:49 pm #125400KubicixfactorMember
Thanks very much!
Incidentally I'm looking to reproduce the drum sound used by Tony Visconti on David Bowie's "Low" album which I believe involved detuning the snare by a semitone and looping the output back into the harmoniser.
February 12, 2014 at 3:02 pm #136189
I think Visconti describes this in his autobiography "Bowie, Bolan and the Brooklyn Boy"
February 12, 2014 at 4:53 pm #125401brockParticipantQuote:I've tried using the scale/speed knob to select "chromatic" but the display still shows a decimal scale.
You may not need the MIDI control references here, but there are links to some pictures and original documentation that will give you a visual idea.
By the way, I think that you'll find that you can create the effect internally with feedback, without having to re-route the output.
February 12, 2014 at 5:25 pm #125402KubicixfactorMember
Thanks very much, really helpful stuff.
So I guess the original 910 didn't have any of its own feedback regeneration then? Useful if I can do this within the Pitchfactor, I'll be able to recreate the sound I want live.
February 12, 2014 at 5:36 pm #136190
It has a feedback control. Here's a video that someone posted last year playing with the original hardware. http://www.youtube.com/watch?v=4r1NZuKJyKI
February 13, 2014 at 12:25 am #136191brockParticipantQuote:Incidentally I'm looking to reproduce the drum sound used by Tony Visconti on David Bowie's "Low" album … if I can do this within the Pitchfactor, I'll be able to recreate the sound I want live.
The guy from Eventide answering all of your questions above is certainly more qualified that I am here. He invented it. But this should get you started:
BreakingGlass
Mix = WET:50
Pitch Mix = A10+B10
Pitch A = A: 0.944
Pitch B = B: 0.944
Delay A = 30 ms.
Delay B = 30 ms.
(encoder) = 910/949/ TMP OFF
Depth / Key = H910
Speed / Scale = CHROMTC
Xnob = FBK-A: 80
Ynob = FBK-B: 80
This uses both pitch shifters set up identically; you may only need one. Adjust the Pitch or Delay knob slightly in one of the pitch shifters to get a thicker sound. General rule of thumb for this kind of effect: Longer delay time – less feedback level.
If you want to remain 'authentic', keep the Depth/Key knob on H910, and have your Delay set close to an increment of 7.5, 15, 30, and 60 ms. [the original switch selections – up to 112.5 ms.]. Of course, a setting of MODERN with any number of milliseconds is fair game, and noticeably cleaner.
The PitchFactor makes it easy to switch between downshifting and upwards pitch shifts with an aux switch, expression pedal, or over MIDI. Move the Mix knob higher for more effect with less of the original signal.
February 13, 2014 at 8:14 am #136192KubicixfactorMember
Thanks, I was playing with this setting and it's excellent, really appreciate the help I've had!
