January 9, 2005 at 8:12 am #105205
Posted by dmtny1
I am having the same problem as a previous poster.
After Installing the Eventide H949 from the Massive Pack 3 CD,
The H949 shows up in the Plug-Ins Folder but does not show up in the plug list when a session is open.
I have checked the digi site for updates but the CD I have is the most recent Version. I have tried re-installing several times by both uninstalling first and by trying to install to replace the previous version, all have failed to produce a different result.
I am Running Pro Tools 6.7 on a Dual 2.5 ghz G-5 with Mac OS 10.3.5
does anyone have a solution to this?
January 13, 2005 at 1:37 am #116696
Posted by Dan
Does the plug-in show itself as loading when you start protools? Did you ever get the Pace screen to authorize the plug-in at protools startup?Thanks,
Dan Gillespie
Eventide Inc. -
January 19, 2005 at 3:04 am #116697
Posted by dmtny1
Hello Dan,
It does not appear to show up when Pro Tools is loading.
I don’t recall getting the Pace screen but I’ve tried re-installing this so many times it’s really hard to remember. I don’t think so though.dmtny1
January 19, 2005 at 3:37 am #116698
Posted by dmtny1
I’d like to correct one thing. The Harmonizer does show up as loading when Pro Tools starts up.
dmtny1
January 19, 2005 at 10:34 pm #116699
Posted by dmtny1
Hi Dan.
okay, the problem is that I generally work at 192khz when I record music. The plug-in works at 44.1khz and 48khz.
Is there an update planned for 192khz ?Best,
dmtny1 -
January 28, 2005 at 11:06 pm #127802
Posted by Dan
I’m sorry an answer has been a little long in coming. No one was able to check the forums as we were all having a great time at NAMM.In order to answer your question, unfortunatly there are some technical reasons that the H949 will only run up to 96kHz. The compatability of all Eventide plug-ins can be checked at http://www.eventide.com/plugins/compatable.htm.
Thanks, and let me know if you have any other questions,
Dan -
May 5, 2019 at 10:27 am #151849
Hi, how can I buy the H949?
Thx.
Thx.
Hi, H949 isn't currenlty available by itself in native format. It's available in the Anthology XI bundle and Ensemble subscription.
