H9k Algorithms used more than once can’t respond to separate MIDI channels
Home Forums Products Rackmount H9k Algorithms used more than once can’t respond to separate MIDI channels
    • #158498
      John Baylies
        Algorithms can respond to separate MIDI channels, and can be controlled separately if there are duplicates.
        I'm having trouble reproducing your issue.. Could you provide more information about your setup? Which algorithms you're using, which MIDI controller, etc..
      • #116639
        moschops
          HI,
          If you are using 2 or more of the same Algorithms in a session, you can’t control them separately.
          I could make a duplicate but Eventide have locked lots of Algorithms which limits the flexibility.
          I think Algorithms should be able to respond to separate MIDI channels no?
          Thanks for listening.
