H9k cpu use meter?
Home Forums Products Rackmount H9k cpu use meter?
    • #116622
      moschops
      This would be useful I think?
    • #158446
      John Baylies
      I think it's best to keep it simple with the current "it either works or it doesn't" approach.
      Ideally the H9000 would automatically label your custom Vsig3 algorithm and warn you if it overloads a DSP at a certain sample rate.
    • #158493
      moschops
      Respectfully disagree, having a cpu meter would allow one to plan a session much more effectively, for instance one of your FX chains might be using way more CPU than another but you won’t know that if you’re only told when you’ve reached the limit.
