Home › Forums › Products › Stompboxes › H9s showing serial number vs name in Control app on Android
- This topic has 12 replies, 2 voices, and was last updated 2 years, 4 months ago by
bohan
Eventide Staff.
June 26, 2022 at 2:50 pm #164188
axman53
ParticipantI’ve been happily using two H9s on my board and controlling them live using an Android tablet with the H9 Control app. One of the first things I did several months ago was to enter a name for the H9s so they would show on the left nav of the Control app with names instead of their serial numbers. This worked great for months. And then, one day recently, for no apparant reason, both H9s are displaying with their serial numbers instead of the names I configured. In the app, when I look at the device parameters, the names I entered are still there, but they no longer display under the H9 devices. I’d like to get my display names back. Thanks for any instructions.
June 27, 2022 at 6:53 pm #164201
Are the Bluetooth names you set on the pedal still the same (Press Hotknob and Right FSW -> Blue -> Name)?
Not sure what went wrong. Try to reset the app (Settings->Reset all settings) and reconnect to both pedals.
June 27, 2022 at 7:27 pm #164203
axman53
ParticipantAre the Bluetooth names you set on the pedal still the same (Press Hotknob and Right FSW -> Blue -> Name)? Not sure what went wrong. Try to reset the app (Settings->Reset all settings) and reconnect to both pedals.
Yes, Bluetooth names are there. If I reset the app, will I lose anything?
June 28, 2022 at 7:03 pm #164220
No. Resetting the settings in the app won’t lose you anything (but resetting the pedal would).
July 2, 2022 at 1:30 pm #164289
axman53
ParticipantNo. Resetting the settings in the app won’t lose you anything (but resetting the pedal would).
OK, that did not fix it. Interestingly, when the “Connecting” dialog displays when the app first starts, the bluetooth names show: TIME connecting; MOD connecting. But in the left nav the serial numbers only. Any other ideas?
July 8, 2022 at 3:44 pm #164676
I think that is by design. What do they show as at the top bar in the app window?
September 30, 2022 at 8:07 pm #165837
axman53
ParticipantI think that is by design. What do they show as at the top bar in the app window?
The top bar shows the serial numbers as well. What does that tell us?
October 3, 2022 at 10:45 am #165861
Can you take some screenshots?
Where did you set the names of your H9s? I think the names should show in the Bluetooth connection dialog when you connect to them.
October 7, 2022 at 11:56 am #165919
axman53
ParticipantScreenshots you say? Here you go…
October 13, 2022 at 9:05 pm #165986
axman53
ParticipantIs there anybody out there…? Any comments on the screenshots?
October 16, 2022 at 7:36 pm #166000
The screenshots look correct. When you connect to them, you see their Bluetooth names in the connection window. In H9 Control Presets/Preset Lists views, serial numbers are displayed.
October 16, 2022 at 8:10 pm #166004
axman53
ParticipantThe screenshots look correct. When you connect to them, you see their Bluetooth names in the connection window. In H9 Control Presets/Preset Lists views, serial numbers are displayed.
So, I’m imagining things that for the past few years the names have always appeared, not the serial numbers? And what is the point of having the ability to assign a friendly name to a device and have it show only when connecting and not in the app where you really need them?
October 26, 2022 at 6:37 pm #166094
That setting is for changing the Bluetooth name. The purpose is for you to recognize your H9s when you connect to them, or to not allow other people to see the S/Ns of your devices.
