Home › Forums › Products › Stompboxes › Half Bushel of Peach Presets
May 20, 2017 at 10:53 am #114184
Participant50 additional ser presets for the new PitchFuzz algorithm, in a Preset List container.
https://www.dropbox.com/s/vor7pztk3xcm63l/Half%20Bushel%20Of%20Peach%20Presets.h9z?raw=1
Drag ‘n’ drop over H9 Control 2.8.1. Any similarities to [F]actory presets is purely coincidental ( I never touch included presets until well after I’ve explored the new interface. No preconceptions. ) Of course, gain-staging is Audio 101. I’ve zeroed the Output Level in each preset here. Tweak levels to your own system setup.
Every preset (except #50) includes integrated expression pedal control. All HotSwitch mappings were removed.
Half Bushel Preset List:
- Riff Rock Layers
- Pinch Harmonics
- Organ Donor Card
- Quadra-Track DRV
- Machine Gun + EQ
- MGModular Tarkus
- Pedal + Sequence
- Golden Ambiences
- Jazz 7th Chords
- Storm Drain Clog
- Touch Of Octaves
- Off Green Ringer
- Swirl & Harmonic
- Burrowing Basses
- Four Oscillators
- Devilish Tritone
- Brassy PWR Chord
- Minor 3rd & 7th
- Distant Rumblers
- Fibonacci Gold
- Thick & Crunchy
- Europa WomanTone
- Pizzicato Shower
- Down In The 4th
- 2X Echo Addition
- Major 3rd Degree
- Power Chord Down
- Multiwave Octave
- Slap Delay Warps
- LG Bottom Feeder
- Can Can Cleaners
- 05 MAR Exp Drive
- One Third Off
- Multi-Dimensions
- 2-Bass Diffusion
- Own Lonely Peach
- Suspend Animate
- HammerOn Octaves
- Delta Intervals
- Shredded ‘Schroom
- Blue Note Octave
- Stutter Express
- Dreams Of Tahiti
- Multi-Tap Panner
- Trailed By A 5th
- Hoover Bell Lead
- Dyad Spirographs
- Phase Drift Loop
- Higher Altitudes
- Zeroed PitchFuzz [preset programming template]
May 20, 2017 at 11:31 pm #146479
maxpowersr
MemberThank you!
May 22, 2017 at 2:35 pm #146497
st.bede
ParticipantThank you for shareing your presets. I can not get them to load. I draged and drop the folder onto H9 control, the H9 control opens but the presets are not there. Do you have any idea what I am doing wrong? Again thank you much.
May 23, 2017 at 10:24 am #146500
Participantst.bede wrote:… I can not get them to load. I draged and drop the folder onto H9 control, the H9 control opens but the presets are not there. Do you have any idea what I am doing wrong? …Sorry to hear about the issues. I just tried your described method (D’n’D before opening H9 Control), and the same thing happened. If I launch H9 Control first, then drag ‘n’ drop over the open interface, I get “One Preset List and No Presets Imported”. The Preset List [L1000] is loaded up correctly. This is under Windows 8.1.
Let me know if this works for you. I could’ve sworn there was a complementary “Import” action to match the “Export Preset List” command, but apparently I haven’t had enough cafe cubano yet.
May 24, 2017 at 9:18 am #146503
mistercharlie
ParticipantImports just fine on iPad.
May 27, 2017 at 7:29 am #146525
Bodde
ParticipantThanks for sharing Brock! Can you load these as a preset list? So that they don’t show up in the algo themselves but only in a dedicated preset list?
May 27, 2017 at 11:03 pm #146526
ParticipantBodde wrote:Thanks for sharing Brock! Can you load these as a preset list? So that they don’t show up in the algo themselves but only in a dedicated preset list?
I did upload them as a Preset [L]ist, Bodde, and limited that [L]ist to 50 presets. It’d be difficult for me to determine whether the individual presets are available in the algorithm itself. Here’s why:
My process is to build each preset over time. When I’m satisfied, the presets get loaded & arranged in a New Preset [L]ist. So – by design – the individual presets here ‘begin life’ as a [U]ser preset, and show up in the algo.
I do know that auditioning the [L]ist will load each preset into the temporary “0” slot, and then you have to explicitly save it to a slot between 1-99 before it becomes part of your stored preset array (within the H9 pedal).
June 2, 2017 at 4:50 am #146563
st.bede
ParticipantThank you for the awesome presets. Some are mindblowingly hip. 🙂
June 6, 2017 at 12:42 am #146587
ParticipantThat’s the coolest compliment that I’ve gotten in quite some time. Thanks. I tried to mix it up with some bread ‘n’ butter presets, along with the spacy ambient stuff. There’s just so much in there to take advantage of!
If it’s feasible, try an expression pedal (or Aux switch, mapped to the expression pedal programming). Check out the Pedal View tab to really see what goes on throughout the pedal travel. As a rule of thumb, if a preset starts out busy and showcase-y, then the Toe position will tone it down. Conversely, if the preset is a little mild, the Toe position slides in other components & more wildness. Some presets will morph with more subtlety.
For example, a looping-type preset at default will continue to play back. The Toe position of the expression pedal fades it out. Or a favorite trick from the Diatonic algo: delay times are changed & stuttered; depending on pedal position. One of the more powerful targets for expression pedal is the unlikely Voices parameter; simply because of its positioning in the FX routing scheme. PitchFuzz is a crazy-deep algorithm.
June 12, 2017 at 1:29 am #146616
Given To Fly
Participantbrock wrote:That’s the coolest compliment that I’ve gotten in quite some time. Thanks. I tried to mix it up with some bread ‘n’ butter presets, along with the spacy ambient stuff. There’s just so much in there to take advantage of!
Have you met your match, algorithmically speaking?
June 19, 2017 at 7:38 pm #146646
ParticipantGiven To Fly wrote:Have you met your match, algorithmically speaking?
That could very well be, Mark. I didn’t hold out much hope originally, based on the initial NAMM descriptions. But I’ve been pleasantly surprised. The multi-FX structure is one obvious reason for the depth. The voice & effect routings adds another level. It’s the subtle interactions that have captured my attention lately.
For example, I’ll set up some generic gain-staging: guitar volume & tone controls around 7-8; healthy levels using H9 Control’s meters & clip indicators. Flip around the pickup selection, or swap out guitars with similar setups. All of my PitchFuzz presets hold at 0 dB / unity gain now. I’m really liking the variety that I can squeeze out, using only the on-board controls of the guitar(s). Volume / tone are reactive for the full 0-10 range.
And there’s still the occasional Eureka! moment. Just last night, I started exploring wet signal-only, discrete glissando pitch shifts. Something that cropped up here on the forum, & I never followed through on it. All algorithms benefit from expression pedal control, but this one excels at delicate ‘morphing’.
June 23, 2017 at 3:53 am #146681
Given To Fly
Participantbrock wrote:Given To Fly wrote:Have you met your match, algorithmically speaking?
Wow! That certainly is saying something! I must confess, I have not even tried the demo yet. I’ve only listened to the examples. Perhaps it is my natural dislike for peaches and fuzz pedals that it is subconsciously making PitchFuzz a non-priority for me. When that changes I’ll be sure to try out your half bushel of presets.
September 28, 2021 at 8:05 pm #158740
Superkike
ParticipantMuchas gracias por compartir, excelente.
Podrías compartir algo de octaver para acompañar las lineas de solo instrumental y algunos efectos con dotted eight 8th? Estaré muy agradecido con ustde, que tenga un lindo día.
