Home › Forums › Products › Stompboxes › Harmadillo is great! One wish though…
August 5, 2019 at 12:18 pm #115453
I have been playing with Harmadillo and I really love it! You can get good Univibe like tones from it. It even can do Autowah sounds and I managed to get a good bass overdrive sound out of it (although it not intended for that).
I have one wish though. And that wish is the same for all tremelo and arpeggiator based algos and even the square envelopes in the How Sawz and so: I have trouble getting the rhytms in sync. The first attack is always off beat when you play with a metrome and then after the first attack the straight rhythm starts. So it is impossible to sync when not using an extra pedal because you never know where it starts in the cycle. I wish Eventide could build in a retrigger. Meaning the cycle (or wave) restarts at the first attack (or every attack). Hope this it possible?
I think if you tap your tempo using the right footswitch, it will retrigger the LFO so the tremolo will sync the your rhythm.
ok thanks! I didn’t know that. I thought it needed a restart buttom just like the Harpeggiator. Does the right switch also restart the tremelo algo and the sequences in the Harpeggiator? So no need to bring an extra footswitch?
August 6, 2019 at 4:19 pm #152462Bodde wrote:
ok thanks! I didn't know that. I thought it needed a restart buttom just like the Harpeggiator. Does the right switch also restart the tremelo algo and the sequences in the Harpeggiator? So no need to bring an extra footswitch?
The Tap (right footswitch) retriggers the LFO of the TremoloPan or Harmadillo algorithms. It cannot restart the Harpeggiator.
