HarModulator Bug?
Home Forums Products Stompboxes HarModulator Bug?
Viewing 6 reply threads
    • #108261
      cowudders
      Hello, when I turn the PitchMix on this algo 100% to 'B', I get an in-phase left signal and an out-of-phase right one – it cancels out in mono. Is this the way it's supposed to work? I'm running the lastest system 3.0.0[19]  – thanks, bernd
    • #123024
      wedelich
      Hi cowudders,
      So are you saying that when you run two physical outputs out of the pitchfactor, that they cancel out when summed or center panned in a mixer?  I'll look into this, just wanted to make sure we are on the same page.
      Russ
    • #123025
      cowudders
      Hi Russ
      Yes, one side gets phase inverted, which cancels out when I press the mighty mono-button. The other phase-inversion problems from 2.3 are gone in 3.0.
    • #123026
      cowudders
      The mono cancellation only happens when PitchMix is set to 100% 'A' only (the A voice solo).
    • #123027
      wedelich
      I thought it was 'B' only?  I found and fixed the one with 'B' only, so look for this fix in the soon to be released beta.  Are you getting cancellation with 'A' only too?
    • #123029
      cowudders
      Hey Russ,
      yes, sorry, as I wrote in my first message: it's of course 'B' where one side is phase inverted.
      thanks!
      BTW: just got a modfactor – very cool!
    • #123031
      Late to the party here, but I did get a chance to confirm just now.  3.0.0[19] installed.  All of the HarModulator parameters at their most neutral setiings, 100% wet, panned to center in the rack line mixer, and 'B' drops right out.  Nice catch.
