Have DAW tempo control length of loops in bars
Home › Forums › Products › Rackmount › Have DAW tempo control length of loops in bars
Viewing 3 reply threads
    • #165170
      klango
        My apologies if this has been covered before, I was not able to find it.
        H9000R
        Emote as plugin
        Algorithm: 740 5.1 Loop & Freeze
        Set-up View : Tempo Mode is set to ‘DAW’, correct tempo from DAW is displayed
        In the algorithm page, loop parameters: only length in seconds is recognized
        I’m not able to set length of loops with bar parameters
        TEMPO MODE button in the top right of window makes no difference
        Thank you for any suggestions.
      • #165175
        Puppeteer
          That algorithm uses the system timer, which I’m not sure is implemented in the H9000 yet.  See this reply.
          H9000 System timer
          The algorithm may need to be modified to use a tempo knob or something if you want to use this in the short term.
        • #165178
            Yes as Puppeteer mentioned this algorithm will not work properly until we’ve implemented the system timer. We do have a fix for this but we are still in the process of testing it. I’ll update you here once this is resolved, sorry for the inconvenience.
          • #165179
            klango
              Thank you for the reply
