Hi there,
I haven’t been able to find this info yet- My expression pedal and aux switch are working fine with the H9. The issue I’m having is the heel position is 100 and the toe is 0. Is it the cable I’m using (I have tried two and they are the same)? I don’t see a setting to reverse the polarity on the H9 and there’s no expression pedal setting to that either.
I’ve tried both the Dunlop DVP mini and DVP5.
