help for tap tempo
Home Forums Products Stompboxes help for tap tempo
    • #105578
      kanifi
      since the last update ,everytime i reboot TF can' t save my tap tempo setting,anyone can help me so set the tap temp as before only tap and not repeat on and off +tap?cause i am using it a lot even in bank modes
       thx
    • #117380
      Roobin
      So when you tap in the new tempo it doesn't remember? Did you save the patch after you tap in a new tempo?
    • #117383
      kanifi
       when i save presets it work but the aux assignement tap temp with ext pedal doesn't, i have to go everytime in menusystem then aux to learn tap tempo
