Good morning I hope you can help me, I bought a H9 max recently ...
I have a Gibson les Paul and a Laney VC 30 2x12 amp
I use a harley benton fxl8 pro switcher where several analog pedals are connected: OCD, RAT2, MXR MICRO AMP ... etc etc
The switcher output goes directly to the amplifier input
I put the h9 in the send return of the amp which should be parallel (I think so)
My H9 has been configured in this way:
Bypass: Relay
Killdry on
I put the volume of the send return (in the amp) to the maximum
Result:
I get a significant drop in the volume of the dry sound, I tried to increase the output level of the pedal but only the effect increases, for example: on the delay it increases the volume of the repetitions and not the dry signal
I tried to act on the wet / dry of the single effect but nothing I still have a decrease in volume, tried to act on the input through the app by raising the gain but nothing changes,
Do you have any tips?
