help! MF: no midi-signal @ thru/out
Home Forums Products Stompboxes help! MF: no midi-signal @ thru/out
    • #106226
      boba fett
      Hello, first time here,
      I have a problem: Im using a gsc-3 midi board into modfactor into damagecontrol glassnexus into a diezel vh-4.
      The modfactor is blocking the midi signals to glassnexus and vh-4.
      The midi cable is okay.
      Can anyone help me what to do?
      cheers
    • #118606
      IDeangelis
       Hi boba
      welcome to the forum.
       Your MIDi is very ikely set to OUT. You can change it to THRU to pass incoming MIDI data to the next unit(s) in the chain. Check the manual to learn how to enter the System area and make the necessary change.
      all the best
      I
