Help.. my H9 Max cannot received any signal from my guitar
Home Forums Products Stompboxes Help.. my H9 Max cannot received any signal from my guitar
Viewing 4 reply threads
    • #113660
      Evolution
        had a gig and my h9 was working fine. then turn it off.. went home… in the morning when i want to play the guitar, i turned it on and no sound at all coming from my amp. i test every pedals i used, everything fine except my h9. i tried just using guitar > h9 > amp still no sound. the green LED also didnt blink at all.
        help me please
      • #144199
          Make sure you are plugged into input 1 and output 1. Try different cables.
          Is there normal activity on the display ? If not look at the power supply and its plug.
        • #144200
          Marcel
            Probably not, but perhaps it is in muted Tuner mode.
          • #164695
            geescalante
              I’m having the same issue no sound on bypass or when engaged. Cables I’m using working perfectly fine, connected to input 1 and output 1, normal effects settings, it’s in DSP mode, factory reset it and even updated it still no sound. The green light don’t come on. Signal chain is guitar-> H9 -> focus rite interface
            • #164702
              apalazzolo
                This happened to me.  I searched the Net in vain for answers.
                I learned that those in the know know that the lack of green light means your H9 needs repair.   Few will respond to a question like this b/c they don’t want to be the bearer of bad news.
                They don’t want to break this to you: stop wasting your time looking for answers.  Just send it to Eventide with $100 (a very good deal). Good luck.
