Ok let me first attempt to understand how the chorus effect works. We take some signal and delay it by x ms. To get the "chorus" sound we modulate the delay by some amount.
Ok so does the Xnob on Organic chorus set the minimum delay? What I really want to do is have a delay that is modulated with a triangle wave with about 3ms of offset.
So Depth controls how much I change that that delay and speed controls how frequently it goes from delay_max to delay_min correct?
How does intensity work. Is this like a dry/wet mix knob for this effect?
I still can't believe no one at eventide has tried knocking off the CE-1. Guess I'll keep tweaking and working of deciphering the schematic.
