Home › Forums › Products › Stompboxes › Help with bypass when “kill dry” selected
December 19, 2014 at 4:13 am #112168
boyce89976
ParticipantI would love to run my H9, Timfactor and Space in the effects loop of my amp, but when I select "kill dry" the bypass changes to "mute" and mutes the signal after the muted effect, including the dry signal from in front of he amp. I understand why you would want it this way in a wet/dry rig running parallel effects paths, but it's not useful at all for a serial effects loop.
I could run everything at 100% mix, but that doesn't work either, as I want to have different mix levels per patch/song.
Any ideas how to make this work? Am I missing something?
Eventide, please change bypass for kill dry to bypass, not mute!
December 21, 2014 at 7:14 pm #127202
boyce89976
ParticipantSo I guess Eventide doesn't have a solution for using Kill Dry with effects wired in series?
This is really frustrating. Kill dry doesn't allow effects to tail off when selecting bypass/mute. It mutes the signal past the muted effect, so you lose everything. How about allowing the user to select how the dry signal is handled when in Kill Dry mode, optimally, allowing the dry signal to pass throught the muted effect?
December 22, 2014 at 3:44 pm #127207
MarcoR
ParticipantKill dry is not intended for
a serial loop or serial connections between processors.While there are certainly situations
where you would want to send a 100% wet signal to the next processor in series
(i.e. Flex Whammy effect to a delay or verb), in most situations it would not
be ideal. For example if you were sending a delay at 100% wet to a Reverb (both
with kildry enabled) in a series loop, the output would just be echoes with delay.In my rig, I go from my
preamp to a pitchfactor set to relay bypass so when it’s bypassed, a pure
analog signal is sent through. From there, I split the signal three times and
send the first split to a Timefactor, the second split to a Space and the third
to the “dry Input” of a RJM mini line mixer. The stereo outputs from the
Timefactor and Space are sent to the mini line mixer so that they are in
parallel but still get the wet signal from the Pitchfactor when it is enabled.The Timefactor and Space are
both set to killdry in this scenario and the bypass mode is DSP+FX so when they
are bypassed, the effects spill over.I would find it completely
undesirable to run these in series effectively cascading the A/D D/A
conversions. That said, it can still be done (just not in killdry), you
would you the mix control to set you effect levels and the output levels on a
preset basis to get the desired overall level. Set the bypass to bypass mode is DSP+FX to get spillover.Hope that helps.
December 23, 2014 at 1:12 am #127214
boyce89976
ParticipantHey man, this is very helpful, thank you. One question, though. You say your TF and Space are set to killdry but the bypass mode is DSP+FX? I can set mine like that, but I lose spill… it mutes instantly… possibly due to my serial effects loop?
December 23, 2014 at 1:44 pm #137848
MarcoR
Participantboyce89976:
The difference is series vs parallel routing. In serial routing as you have, when you bypass
anything in the chain, the following effects are no longer receiving a signal when using [DSP+FX].I would think if you had
a delay last in the chain and you bypassed that effect, the result would be,
the echoes trail off but the rest off your signal would be muted.From the Timefactor
manual:When [DSP+FX] is selected,
Bypass combines the audio at the DSP’s inputs with the DSP’soutputs AND
stops feeding any new input signal to the DSP Effects inputs. This is a
handyway to Bypass an Effect
without abruptly killing the tail of the Effect that you’ve been using.Try using DSP or Relay; you won't get trails but it will output to the next effect in the chain.
