Help with H9 Pairing
Home Forums Products Stompboxes Help with H9 Pairing
Viewing 3 reply threads
    • #169871
      zylent
      I have 2 H9 one Max and one normal. Today I tried to make the normal work and it is not listed in the bluetooth section. It appears only as ????. I tried on Ipad, and cell phone and it couldn’t. What can be? It turns on but when I press the “Active” button, the sound is not activated either. I have never reset it to the factory or updated it for fear of losing the MAX OUT since being the normal version it was maximized by having the MAX version.
    • #169874
      Sorry for the issues you are having. Updating or factory resetting your H9 will not affect the Max status, once the pedal is Maxed out it will remain that way forever.
      To start, I’d suggest updating your H9 to the latest firmware and if you are still having issues, then you can try a factory reset.
    • #169875
      zylent
      The updater says : “Retrieved 0 Eventide Devices”. It didnt work, also when i turn on the H9, the message UNPLUGED is on Screen, also the TAP and ACTIVE Lights are turn off even if i press the button.
    • #169877
      Sorry to hear that didn’t help. It’d be best to email support@eventide.com and we can help you troubleshoot this further there.
