I am using a Morningstar MC6Pro as my midi controller. Is there a way for certain programs to receive midi clock but have others have predetermined/set tempos that are unaffected by incoming clock?
Not possible because MIDI clock is a global function. It’s either on for all or not at all. The way around this is if you leave Tempo Sync off for the Programs and presets you don’t want to sync to MIDI Clock. This requires you to enter delay values manually.
