hi!
during my live performance, i use mono mode & stereo input mode – is there any way to change this setting via midi, or do i have to manually set it via the levels menu?
i am splitting the signal from my guitar – and only need both feeds for some tracks where i route one feed through effect block a , and the other through effect block b …
Where i am using one feed from the guitar, i use effect block a & b in series
any ideas on what could make a smoother live transition between these settings?
cheers in advance
dan
