Help with setting Input volume
Home Forums Products Stompboxes Help with setting Input volume
    • #113495
      garbeaj
      I try to set the Input volume according to the directions in the instructional videos and when I press and hold the “Active” button, it only lets me adjust Output volume. I can’t find a way to adjust the input volume.
      Thanks in advance for help with this newbie question!
    • #143534
      gkellum
      The input level moved.  It's now under System Settings.  This is described in pg 43 of the most recent version of the H9 User Manual:
      https://www.eventideaudio.com/support/downloads/h9-user-manual
    • #149982
      teabandito
      Is there any way to reduce input gain or level? I use my H9 in the loop of my amp and it is a bit clipping so I have to reduce output level in any preset for to -20Dи which is not that good. I also cannot lower the volume of the amp loop so the reducing of the inout is my only hope 🙁
