Help With TF Expression Pedal Please!
Home Forums Products Stompboxes Help With TF Expression Pedal Please!
Viewing 6 reply threads
    • #105298
      mcalldp
      Hi guys, I have the Eventide Time Factor and am running a Roland EV-5
      expression pedal to it. From the instructions it seems like I just put
      the heel all the way down on the pedal and adjust a know, put the pedal
      all the way up and adjust it again, but I am getting NOTHING. I did
      just download the new 2.0 beta version but it wasn't working before
      that either. Is there some setting I have to activate to get this
      working or what? Please help! Thanks all
    • #116859
      tagnello
       I think that the EV-5 has a trim pot adjustment. Try setting it to either extreme.
    • #116860
      wes
      I also have a problem w/ my line6 exp. It will only change a pedal up to 76% of its potential. Does anyone know how to fix this?
    • #127874
      18watt
      FYI, my Boss FV-500L works perfectly.
    • #128329
      joeyray
      I had same problem.. Just unplug the expression pedal from the TF while it's on and then reinsert it…works for me…I'm using homemade expression pedal
    • #128331
       The TF expression pedal will autocalibrate at power-up and when the pedal is removed and re-inserted, so the last suggestion is good.
      But, if you have to do this all the time you will become annoyed. Probably, first thing to try is another pedal, preferably one with a record of sucess with TF. See FAQ for details.
      Some pedals will not work well – particularly those with a very high resistance pot. Also, look for an adjustment knob on the pedal.
    • #128334
      Mike33
       I use a line6 expression pedal and it works without any issues….
