Help with Vocoder / VOX presets.
Home › Forums › Products › Rackmount › Help with Vocoder / VOX presets.
Viewing 4 reply threads
    • #107333
      Hi all.
      I want to use the Eventide in the following way.
      Midi notes going into the eventide while I am singing (also going to the eventide), the purpose is for
      Real time pitch correction of my singing or classic Vocoder use.
      When I apply the Vocoder presents my singing sound is changed, but there is no relation with my
      MIDI notes.
      appreciate help with this one.
      Thank you
      Tomer.
    • #120871
        Kinda hard for me to answer when you don't say which vocoder you are using.
        But, some of them have a MIDINOTE module which will receive MIDI note messages (e.g. 6812) and others do not (e.g. 6810).
        It's probably a matter of picking the right preset, or, if you have Vsig skills, adding MIDInote functionality to one that does not have it.
      • #120873
        Thank you for your help.
        I will try this presets.
        Are there are VOX/Pitch correction presets with midi module?
        Tomer.
      • #132082
          Pitch correction presets tend to be automatic, so do not usually have a MIDInote input. The following presets have MIDINOTE:
          2410-2417, 2419,5218,5224-26, 6812-6816, 8421.
        • #132083
          Thanks
          This is helpful, I will try this and update
          Tomer.
