Host timeout error
Home Forums Products Rackmount Host timeout error
Viewing 3 reply threads
    • #107281
      ThreeFingersOfLove
      I have a weird problem over here with my H8000FW. I use the dual analog configuration and I have the same preset loaded on both DSPs. All of a sudden the B processor got muted, LEDs showed activity but no sound. Reselecting a preset rectified this. After a while I got another mute in DSP B and a little later I got a "Hosttime out error for B – suggested power down".
      This is frustrating, any ideas here?
      Regards,
      Yannis
    • #120779
      This is a message that may be caused by a hardware fault or by a DSP crash.
      If it is the second, it will tend to be associated with a particular (usually large) preset or presets. Is this the case here ?
    • #120781
      ThreeFingersOfLove
      Hi Nick
      thanks for the swift reply. Preset is a modified version of 3910, I opened it in VSig and it doesn't seem particularly big. Others are much bigger. It hasn't done it again, since I posted this.
    • #131989
      It's not always the physical size, more the amount of dsp power it needs.
      Hopefully, it won't do it again, but you'll be watching it ..
