HoTone FS-1 Ampero Switch
Home Forums Products Stompboxes HoTone FS-1 Ampero Switch
Viewing 4 reply threads
    • #171564
      ozgurh
      I bought HoTone FS-1 Ampero Switch for my H9 but it jumps the presets by 2 not 1 by 1
      Anyway to fix this or its not compatible with H9 ? I have checked h9 menu already i found no settings to fix this,
      Thank you
      Ozgur
    • #171567
      joecozzi
      Are you connecting this switch to H9 with a TRS cable? Do you have the Exp Pdl input configured for an aux switch? What do you have the switched mapped to? Make sure it’s not accidentally double mapped to anything else.
    • #171569
      ozgurh
      Switch comes with a cable ( i believe TRS ) and i am using Exp Pdl input and it has only 3 options in the H9 Exp pedal menu and i have tried all of them didnt work. Do i need to make any other changes , setup to make it work ?
      Thank you
    • #171574
      ozgurh
      Thank you , it is fixed now , i havent noticed more settings available under menu ! thanks
    • #171576
      joecozzi
      Happy you figured it out. Thanks for reporting back.
