Hotswitches and H90 control
Home Forums Products Stompboxes Hotswitches and H90 control
    • #187319
      Stratmaster
        I might be an idiot but is there a way to program hotswitches in the H90 Control? I see that you can go into the Edit menu and go to the Control Assignments sub menue, but how do you set a specific parameter to have a specific value assigned to like hotswitch 1? Is there a way to do this or do you have do do it on the H90 pedal (witch seems very complicated to me (I am an idiot I guess)).
      • #187321
          In the H90 Control Edit page: check out the small icons bottom right.  (18) in the link below:
          https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/h90-control/edit.html.
          HS1 – HS2 – HS3
          • Click on one of these, and it’ll (probably) show all of the parameters grayed out.
          • Click on the upper right of any parameter to (+) and adjust the now active value.
          • PGM reverts back to show all of your base Program settings
          • That particular HSx Performance Parameter should now toggle between settings
          • #187361
            Stratmaster
              In the H90 Control Edit page: check out the small icons bottom right. (18) in the link below: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/h90-control/edit.html. HS1 – HS2 – HS3
              Thank you so much – there it was right in front of me 🙂
              Now I can start to really dig in to this!
