how are people getting 50 banks?
Home Forums Products Stompboxes how are people getting 50 banks?
Viewing 3 reply threads
    • #107486
      I upgraded to v3 (beta) and still only get 10 banks. Sorry, I'm a newb to this pedal.
    • #121231
      rabiddiabetic13
        After entering System mode, turn the Encoder to select
        [UTILITY], then press the Encoder to
        enter the Utility functions settings mode. Turn the
        Encoder to scroll through the following
        Utility functions. Press the Encoder
        to select and set:
        [BANKS] – Select
        the range of Active Preset Banks
        (1 – 50)
        Press the Encoder to select. Press the Left Footswitch to
        select the lower limit and the Right
        Footswitch to select the higher limit. Turn Encoder to
        set the lowest and the highest active
        banks. Only Presets saved in active Banks are available
        for loading using the Footswitches. All
        Presets may still be loaded using MIDI
        program change.
      • #121232
        You'll need to set the maximum number of banks in the System Utility menu in order to access all 50 banks. In the user manual, this is towards the end under "System Menu Tree" >> "[UTILITY] – Utility Functions" >> "[BANKS]". You can set the number of available banks from 1 to 50.
      • #121233
          Note that there is a bug (sorry) which can make it hard to go beyond 49 banks. Off by one strikes again.
