How can I set up such a sound with H90~?
Home › Forums › Products › Stompboxes › How can I set up such a sound with H90~?
Viewing 3 reply threads
    • #177939
      simon.ssdssd
        <span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>https://www.youtube.com/watch?v=bjMI8oA1RGU</span></span&gt;
        How can I set up such a sound with H90~?    🙂
      • #177940
        simon.ssdssd
          The clean tone in the first half is really good~
        • #177941
          guitarguy107
            You can’t with the H90 by itself. You need EQ, compressor, reverb and delay besides the amp and cab.
            • #177986
              simon.ssdssd
                This is indeed the case ~ I need more detailed adjustments
            • #177947
                I would suggest trying a combination of WeedWacker for some transparent overdrive flavor, along with SpaceTime for chorus/reverb/delay. If you start with the Nice Chorus preset from SpaceTime, turn Mod Amount down a bit, and turn up the Delay Level and Verb Level, you can get a nice sound. If you turn Verb level up enough it will make the delay and reverb in parallel, which I think sounds nice for this sound.
                With the right guitar and amp, you should be able to get something similar to your example.
                • #177987
                  simon.ssdssd
                    Thank you for your help, I am going to start working according to your ideas ~ I am a little excited now 🙂
