How digital clipping is handled by Eventide?
Home Forums Products Stompboxes How digital clipping is handled by Eventide?
Viewing 8 reply threads
    • #106651
      mauriciobahia
      Hi.
      I know there is a usefull LED indicator but I'm really curious why other digital stompboxes don´t use this light indicator and how Eventide handles this clipping issue internally. Is there a buffer,a limitter?
      Thanks a lot Smile
    • #119517
      There is an analog soft clipper at the front end, and then many effects have compression or limiting.
      The LED lights a bit ahead of the overload point as a warning.
    • #119519
      mauriciobahia
      Thanks in advance!
      Would you mind pointing any situations I should be aware in order to avoid this "clipping" issue? I mean if I use a guitar with an active pickup or Boss SD-1pedal plugged into Modfactor. Is there a proper volume level to be set?
      M.
    • #130647
      You have to drive it pretty hard to hit the limiter.  The first defense would be the guitar/line switch on the back panel.
    • #130648
      mauriciobahia
      Sorry Nicholas, my english is not very "sharp" (I speak portuguese). What do you mean by "drive it pretty hard"?
      Thanks a lot for your time.
      M.
    • #130651
      Apologies..
      "drive it pretty hard" = "give it a very high signal level"
    • #130652
      mauriciobahia
      Smile
      Nicholas, my last question. I promisse!
      When you said "and then many effects have compression or limiting"  are you talking about Eventide stompboxes effects or other brands?
      M.
    • #130654
      I'm talking about our effects – but don't ask me which ones have which – too difficult.
    • #130655
      mauriciobahia
      I would´t ask that! Smile
      Thanks again!
