How do I assign the “Learn” function to a momentary footswitch while using the Diatonic Effect in Bank Mode?
Home Forums Products Stompboxes How do I assign the “Learn” function to a momentary footswitch while using the Diatonic Effect in Bank Mode?
Viewing 6 reply threads
    • #108696
      dannywacker
      I have a Boss Momentary Footswitch connected to the Aux Switch on the back of the Pitchfactor. How do I assign the "Learn" function to the footswitch while using the Diatonic Effect in Bank Mode?
      Can anyone help?
      Thanks
    • #123391
      Don't think you can – the Learn function is a part of system mode and can't be remoted. Not clear why you would need to do this ..
    • #123392
      wedelich
      Actually, I'm pretty sure you can do this by using the FS2 option for that aux switch in the aux switch system menu.
    • #123393
      dannywacker
      Thanks!  Using the FS2 option for the aux switch in the aux switch system menu worked. Now when I'm using the Diatonic Effect, I can change keys instantly by pressing the footswitch while playing a note, and that note becomes the root note of the key.
    • #123394
      Confusion on my part – I thought you were talking about MIDI Learn, to which my comments would apply. Since you are instead talking about Flex Learn, Mr.Wedelich is of course correct.
    • #134481
      dannywacker
      Understood. Thanks for the reply back.
    • #123395
      Another option is to assign the aux switch to FLX.  It works in either Play or Bank mode, and it targets one specific function.  And that function will trigger a different type of variation for 9 out of the 10 algorithms (including Learn for either of the two Diatonic modes).
      You can get unpredictable, but interesting results with a latching switch on LEARN (not recommended by Eventide).  That's a little more useful for the Flex functions in other modes, though.  MIDI triggering is another control option for Flex/Learn.
