Hello.
I am using 1 H9 Max.
Set the tap tempo via aux s/w ad change the preset via EFX 62M.
H9 is used as globaltap tempo.
The Problem is that if you change the tap tempo value, the decay value changes when you recall the reverb algorithm.
I would like tap tempo to be applied to dela tap tempo, tremolo speed…
Is there a way for the reverb’s dacay to be unaffected?
If you use the midi clock pedal to change the tap tempo to midi clock, Are there any effects of decay?
Thank you.
